Question erreur 404 sur les pages site
je crois que tu te compliques la vie en voulant comme ceal
Tu as chez ton hébergeur la possibilité de créer plusieurs sous domaine
- miroir.monsite.com
- miroir2.monsite.com
- miroir3.monsite.com
- ainsi de suite ...
ce sera bien plus simple que d'essayer de faire de la réécriture dans un autre dossier d'uns sous-domaine
Le htaccess suivant conviendra dans tous les cas
RewriteEngine On
IndexIgnore *
Options +FollowSymLinks All -Indexes
## Begin - Rewrite rules to block out some common exploits.
# If you experience problems on your site block out the operations listed below
# This attempts to block the most common type of exploit `attempts` to Joomla!
# Block out any script trying to base64_encode data within the URL.
RewriteCond %{QUERY_STRING} base64_encode[^(]*\([^)]*\) [OR]
# Block out any script that includes a <script> tag in URL.
RewriteCond %{QUERY_STRING} (<|%3C)([^s]*s)+cript.*(>|%3E) [NC,OR]
# Block out any script trying to set a PHP GLOBALS variable via URL.
# Block out any script trying to modify a _REQUEST variable via URL.
# Return 403 Forbidden header and show the content of the root homepage
RewriteRule .* index.php [F]
## End - Rewrite rules to block out some common exploits.
RewriteCond %{HTTP_HOST} !^www\. [NC]
RewriteRule ^(.*)$ http://www.%{HTTP_HOST}/$1 [R,L]
RewriteBase /
## Begin - Joomla! core SEF Section.
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
# If the requested path and file is not /index.php and the request
# has not already been internally rewritten to the index.php script
RewriteCond %{REQUEST_URI} !^/index\.php
# and the request is for something within the component folder,
# or for the site root, or for an extensionless URL, or the
# requested URL ends with one of the listed extensions
RewriteCond %{REQUEST_URI} /component/|(/[^.]*|\.(php|html?|feed|pdf|vcf|raw))$ [NC]
# and the requested path and file doesn't directly match a physical file
# and the requested path and file doesn't directly match a physical folder
# internally rewrite the request to the index.php script
RewriteRule .* index.php [L]
## End - Joomla! core SEF Section.
- tonnerria
- Membre platinium
- Remerciements reçus 18
